Thread: Plumbing leak at pump
    Is there any way to fix this leak without changing out pipe? If I need to cut it what all is involved? Looks like the pipe is threaded into the pump?
    built 4/08/2000 16 x32 460 Sq FT Pool 16,000 gallons 3.5 ft 5 ft 3.5 ft sport pool
    Re: Plumbing leak at pump
    One is the pump that leaks and other one that is fine
    38,528
    You will have to cut the pipe in order to try to fix the leak ... that one looks like a mess with all the silicone and electrical tape? (neither of which is ever going to help).
    You many need to cut the veritcal pipe and add a union fitting to allow you to remove, clean/replace, and then use pipe dope to try to seal it again.
    New Brunswick Canada
    819
    ^ second what Jason says, man what I am learning about installers now that I am running a pool service business Sure wish some would read how to plumb properly, not cheaply.
    https://www.youtube.com/watch?v=o5V6P0IQpM4
    this looks what I need to do
    Well ran into a problem..no one carries this 2" fitting extender he references
