Thread: How many light bulbs? Pump...
    Aug 2014
    So cal
    17
    Just curious, about how many light bulbs does my 1 speed 1hp whisperflo use? 20k no solar.
    38,275
    Re: How many light bulbs? Pump...
    The pump has 0 light bulbs
    It likely uses at least around 1600 watts ... so depends on the size of your light bulbs.
    Aug 2014
    So cal
    17
    lol, is 50 watt the average?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by scannon View Post
    CFL, LED or INC?
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    mas985's Avatar
    Pleasanton, CA
    11,737
    1800-1900 Watts if is a full rated or 1500-1600 watts if it is up rated and it also depends on the plumbing.
    Mark
    22,548
    If we use 60 watts (a common household size) as the standard, your pump will use about 30 incandescent light bulbs worth of electricity, or about 140 equivalent CFL's, or about 190 equivalent LED's.
