Results 1 to 7 of 7
Thread: Going away for 8 days what do I do with the pool?
    Aug 2014
    Coral Springs, FL
    7
    Question Going away for 8 days what do I do with the pool?
    I'm going on vacation next month for 8 days and don't really have anyone to manage the pool while I'm gone. A friend has a pool guy come over once a week and maintain the pool by pouring what I'm assuming is a crazy amount of chlorine in the pool to keep levels up for the full week. Can I get by doing that, if so what should my target FC be or can I do the pucks everyone hates (never used these before) just for the week given my CYA levels are at a manageable 35 ppm level. I live in South Florida if that makes a difference.
    Last test results:
    FC=5
    pH=7.6
    TA=60
    CH=170
    CYA=35
    9,500 Gallons
    IG
    Jacuzzi Cartridge Filter
    Hayward Navigator Pro Cleaner
    38,267
    Re: Going away for 8 days what do I do with the pool?
    Since your CYA is actually relatively low for your climate, there is no problem using some tablets while you are gone.
    Do you have a cover? You could raise the FC up to shock level and cover the pool ... and/or add tablets in a floater.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I vote for using some pucks. Won't hurt one bit to raise your CYA level some. 😎
    Jeff
    Aug 2014
    Coral Springs, FL
    7
    Thanks. I do not have a cover so I think I will go with the pucks. Any particular type of puck better than the other. Also any idea how many to put in the floater for the 8 days? I'm assuming to put the floater on a low release setting.
    9,500 Gallons
    IG
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Honestly I don't have any experience with using pucks or the floater, I'm a bleach dumper 100%.
    The only difference in pucks I believe is the size, weight. As for how many, fill the floater up and I'd say no more than half way open. Just make sure you getting enough chlorine in the water.
    I'm sure somebody with experience with these will come along. 😎
    Jeff
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Check the active ingredients on the pucks. You don't want anything with metals (copper, silver) or minerals. I also would not used cal-hypo pucks. Just CYA and Trichlor/dichlor for the active ingredients. Put one or two in a floater, bring the pool to shock level and let the pump run on a timer. If you get a lot of debris in your pool get someone to empty the skimmer basket.
    Love TFP? Become a
    TFP Supporter!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    See I told ya somebody that knows would come along !!
    Take that advice ^^^^^^. 😎
    Jeff
