Results 1 to 8 of 8
Thread: New backwash valve how to plumb
    Apr 2014
    California
    97
    I got a new backwash valve because my old one broke and am trying to figure out how to replace it since the straights going to it don't have any play, how can I get a new piece of pipe into the new valve?
    38,521
    Re: New backwash valve how to plumb
    Usually you just use PVC/CPVC solvent to attach pipes to the valve, but I am not sure that is what you are actually asking.
    Would pictures help convey your concern?
    Apr 2014
    California
    97
    I do have a photo but I'm posting on my phone, I mean how do I get a coupling on straight pipe that won't move
    38,521
    Sorry, I still do not follow. Easy to attach pictures from your phone in Tapatalk and hosted by them (if that is what you are using).
    Apr 2014
    California
    97
    So I installed the new backwash valve and I didn't use enough glue because I was scared of it falling on the sliding piston assembly and I have a small leak, what should I do
    38,521
    Not sure. No good solution.
    You could drill out the pipe with a ram bit and try again.
    Apr 2014
    California
    97
    Is there anyway to create a vaccum to suck new glue in
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Short answer is 'no' on the suction.
    Photos or a link to the model you have would be of great assistance. Depending on make/model it may allow use different size pipe on the inside and a larger size on the outside of pipe. Say 1.5 inside the valve body fitting and 2.00 on the outside.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
