Thread: pH constantly high
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    pH constantly high
    Hello,
    I've just started up my hot tub after having fitted a ChlorMaker salt chlorine generator.
    I've got my Salt to 2,000, CH to 300 and TA to 75, but my pH keeps going over 8.
    And if I add muriatic acid to lower it, it'll lower the TA too!
    I know that adding the borates will help stabilise the pH, but I read that you shouldn't add the Borax / Muriatic acid until the pH & TA are at the correct levels, so I can't add them yet.
    Is the chlorine from the SWG raising my pH on a constant basis..?
    If so, how do I work around this?
    My pH was under 7, so I ran the tub for 40 mins with all air jets & waterfall on.
    Then it read over 8!
    Jacuzzi J480 (2008) 1700 litres, Balboa ozonator, Delta EZ-18-120 UV lamp via custom 6-way 2-tier timer solenoid array, 2 x Waterway 4HP main pumps,
    1 x Aqua-Flow 1/15 HP circ pump, ChlorMaker IL SWG, SmartSeal + Roxul skirting insulation, 8' x 8' ThermoFloat Spa blanket, 100" x 100" Gator coverall
    Re: pH constantly high
    In a spa/hot tub the rules are different than in a pool. You seem to be mixing pool recommendations into what you mentioned reading above.
    With a spa/hot tub you simply lower TA until the PH stabilizes at something reasonable. There is no reason to aim for a TA of 75.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Due to the high amount of aeration in hot tubs, a lower TA will help combat pH rise. I lowered the TA in my spa to 50 and kept it there most of season. Just before my last water change, it was near 50.
    You can read the How do I use Chlorine in my Spa for reference on recommended levels. I know you're using a SWCG but the recommended levels are still valid.
    Isolated Spa - 345 Gallons
