Results 1 to 11 of 11
Thread: What is causing this green sludge foam in hot tub?
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    What is causing the foam? Foam by the wall is dark green
    Seems to happen after backwash, but I just put in a lot of algicide
    Owner since August 2014. 21,500G Liner In ground Pool with attached 600G plaster in ground hottub. TF-100 Test Kit, Filter: Pentair TA60D Clearpro Sand (HTH) Filter. Pool: 1 Drain, 2 Skimmers 4 Returns. Hot Tub: 1 drain, 1 skimmer, 2 returns. Hot Tub/Pool run by Sta-Rite Dura Glas Single Speed 1.5hp P2RA5F-182L pump with Emerson K63CXESE4972 motor. Spa jets run by Sta-Rite Dura Glas H/L model number unknown.
    Jun 2013
    East TN
    309
    Re: What is causing this green sludge foam in hot tub?
    What have you been putting in it?
    What type of algaecide?
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    SAMs club stuff, "pool brand"
    Jun 2013
    East TN
    309
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Yes, that's it
    Jun 2013
    East TN
    309
    Alkyl (50% C14, 40% C12, 10% C16) Dimethyl Benzyl Ammonium Chloride is a quatanery algaecide and will foam. It is not recommended to use that type.
    It looks like you need to slam your hot tub. The chlorine will get rid of the foam (and the algeacide too). It will probably eat up your FC until its mostly gone.
    The green you see in it is probably alge being killed.
    Jun 2013
    East TN
    309
    Also that type of algaecide will likely leave a black residue behind that feels like grease.
    Here is the msds:
    http://www.kellysolutions.com/erenew...1_11_50_AM.pdf
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Quote Originally Posted by easttn View Post
    Here is the msds:
    Wow, thanks, what should I be using?
    What is SLAM? Keep seeing that in other posts?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by caliskier View Post
    Read this for recommendations on how to maintain a hot tub/spa with chlorine. Now, that is based on a stand alone spa. Maintained properly like a pool extra "stuff" is generally not needed.
    From the picture it appears to be in ground, but is that stand alone or connected to a pool? If it is connected to a pool you generally need to exchange water regularly so that the spa is maintained along with the pool.
    We do not "shock" our pools, we follow the SLAM Process when there is a problem. For a small spa like that I would just drain/refill it and start over rather than SLAMing. If it is connected to the pool and you have this problem in both places than a SLAM is in order.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Support the site
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Quote Originally Posted by tim5055 View Post
    Thanks, I will look into these, it is a spa / pool combo, it is not clear from the picture.
    Jul 2014
    Patchogue ny
    12
    I've only had green hot tub water after going away for a couple days and not adding bleach. The foam usually for me is the women's residual shampoo left in there hair also clothes detergent left over in the shorts
