Results 1 to 14 of 14
Thread: Replace just the motor or the whole Hayward Super Pump?
    Apr 2011
    Simpsonville, SC
    7
    Motor just went in my 10 yr old Hayward 1 hp Super Pump. To replace the motor will run around 135.00 or I can replace the whole Pump and Motor for 315.00. My question is, is it smarter to just replace the whole unit now or just the motor? I'd hate to go through the whole trouble of replacing the motor (will have to pull the whole pump assembly for access) just to have the pump go in the near future. What kind of life expectancy is there for the pumps? Do they usually last a lot more than the motors?
    And....if I am replacing either unit, would it be beneficial to bump up the horsepower...say from 1hp to 1.5hp? There's about a $100 jump in price...
    Thanks in advance for your responses!
    38,301
    Re: Replace just the motor or the whole Hayward Super Pump?
    The wet ends rarely go bad. I would recommend a new 2-speed motor with a new all new seals, get a "go-kit".
    Unless you need more flow for some reason, there is no need to get a bigger motor/pump ... unless you want to pay more for it and pay more to run it.
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    Apr 2011
    Simpsonville, SC
    7
    Thanks, you mention the 2 speed motor...I'm not familiar with them. How does it operate? How do you switch between the speeds? Right now its just a single speed operated by a timeclock.
    Also, you talked about the "go-kit"... I just replaced the seals in the pump last year (due to some leakage) will I need to replace them again?
    30K Vinyl In Ground Pool,
    Hayward Sand filter,
    Hayward 1hp Super Pump,
    CircuPool Salt water Chlorinator
    38,301
    You would need a shaft seal, but would not need the gaskets or o rings if you just replaced them.
    Simplest to just have a switch to manually select high or low speed. Run on low all the time except backwashing or vacuuming.
    May 2012
    Dallas, Texas
    28
    My Hayward 3HP single speed pump lasted for 8 years before the wet end needing rebuilding and then another 2 years before the dry end started screeching. At that point I replaced it with a variable speed Hayward Eco star. I love the new variable speed because I can run it at 1250 rpm which saved me $75 a month. Another benefit of the Eco star is the wall panel control that came with the pump. I ran a cat5 cable from the pump up through the attic and dropped the cable down inside my kitchen, mounted the control panel on the wall (so I can control the pump from inside house). My old pump would only run 3450 rpm $$$. So, if you can spare the extra $100 I'd say go for it.
    16,000 gallon, IG, plaster, filter= DE 60 sq ft, Pump= Hayward EcoStar SP3400VSP variable speed, Build date= 2004, SPA, Heater= Pentair natural gas 400k BTU, Cleaner= Hayward Navigator (Pool equipment installed 2 feet above pool water level)
    38,301
    No one here is talking about a $900 VS pump. Overkill unless you need high flow rates.
    Apr 2011
    Simpsonville, SC
    7
    Ok, I'm not sure what I'm looking for. There appear to be many different front attachments on the motor. When I search for Hayward Super Pump, the only motors that come up, are the single speeds. Can you recommend a website/websites to search or does anyone know what 2 speed replacement motor fits the Hayward Super Pump?
    New Brunswick Canada
    819
    You can also just buy a dry end, no need to mess with seals and bearings. As Jason said, wet ends rarely have issues. A new dry end would have a warranty as well.
    I am not aware of a dry end available yet for a 2 speed.
    Big savings can be had by running pump and SWG on a timer. No need to be running them 24/7. I run mine 9 hours a day, an that's only for solar.
    Smykowski's Avatar
    Sep 2011
    3,065
    They're out there. I replace my burned up single speed with a 2 speed, 110v motor for under $200 this spring. Noticable drop in my electricity usage.
    Can you post a picture of the pump label? That should give enough info to help match a motor.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Two speed motor for a 1 HP Superpump is the STS1072RV1
    http://www.poolsupplyworld.com/Centu...STS1072RV1.htm
    It is a 230v motor so are you currently wired for 230v?
    Mark
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    If you are looking for a quick reference chart for Hayward Super Pump replacement motors, whether it is single, dual or variable I found this one: http://www.inyopools.com/motors_hayward_super.aspx
    Everything seems to be in order going by my quick skim. Have a gander yourself
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by Citizen View Post
    For the two speeds, they recommend full rated motors on up rated wet ends which is unnecessary and technically not correct although it would still work ok.
    The 1 HP Superpump is an up rated pump and so would require either a 1 HP up rated two speed motor or a 3/4 HP full rated two speed motor which is what I recommended above.
    Mark
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by mas985 View Post
    A.O. Smith's replacement dual speed motors are full-rated, if you do a little service factor-horsepower multiplication you can figure out what HP is necessary for any wet end. So if he wanted to go with a 1HP Uprated equivalent the choice would be the STS1072R 3/4 HP Fullrated Dual Speed 230 Volt
    Either way the one you suggested and the one I suggest STS1072R will work though mine is little less expensive.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Right but Inyo is doing it incorrectly. That was my only comment. I could care less where the OP gets the motor but the STS1072 is the correct motor, not the STS1102 that Inyo recommends. In fact, Inyo does not even have the 1072 two speed on the page you originally posted.
    Mark
