Thread: Found leak in valve on suction side, fixed, huge difference!
    Oct 2014
    San Marcos, Ca
    62
    I am new to pools so I am just learning. I have a 3 way valve before the pump (suction side) adjusting the flow between the skimmer and vacuum. I had air coming in when I added any flow to the vacuum. As a result, the vacuum barely moved. I also had slow flow through the skimmer. I couldn't find a leak in the vacuum line and was getting frustrated.
    Then I thought that it might be the valve. So I cleaned and lubed the o-rings and no more leak! The amount of suction increased dramatically. I was able to cut the watts on the pump in half and the vacuum moves faster than it was with more flow through the skimmer.
    What a difference!
    12,000 gallon IG plaster
    Cartridge filter
    Intellifo VS
    EasyTouch Controller
    Pentair SWG
    38,537
    Re: Found leak in valve on suction side, fixed, huge difference!
    Nice find and fix
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Sweet!
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    May 2012
    Dallas, Texas
    28
    Glad to hear that. I would have never suspected a valve leak. Was it a manually operated Jandy valve? or was there an electric actuator involved?
    16,000 gallon, IG, plaster, filter= DE 60 sq ft, Pump= Hayward EcoStar SP3400VSP variable speed, Build date= 2004, SPA, Heater= Pentair natural gas 400k BTU, Cleaner= Hayward Navigator (Pool equipment installed 2 feet above pool water level)
    Oct 2014
    San Marcos, Ca
    62
    Manual Jandy.
    Cartridge filter
    Intellifo VS
    Pentair SWG
