Thread: walmart great value bleach
    May 2011
    Montgomery, TX
    176
    was at walmart this morning and I see they have a new label on their great value bleach. it's says "easy pour bleach" but removed the info about the % of sodium hypochlorite. I can only assume they did this on purpose and will not buy from them again until they publish this info again. it used to be 8.25%, but who knows now.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: walmart great value bleach
    My WalMart has always had that version, but eh plain 8.25% is there also. Check with the store as they may have just run out of the generic and filled the shelf with the easy pour.
    Support the site
    May 2011
    Montgomery, TX
    176
    Quote Originally Posted by tim5055 View Post
    oh, ok, do you know what % the easy pour bleach is?
    Jun 2011
    Long Beach, CA
    2,781
    I'd stay away from the easy pour bleach as it has some additives that I wouldn't want to add to the water. Stick with the plain unscented bleach.
    Jun 2014
    Lake Jackson, Texas
    133
    +1 on the easy pour. I usually grab a couple of bottles of 8.25 every time I go to Wally World but ran out. I grabbed 8 last time I went. One of those (unknowingly) is the easy pour. I just poured some in and noticed some soap bubbles. I checked all my other bottles and I'm good. The labels are very similar and there is not percent specification on the easy pour bottle.
    25K gal FF; QuartzScapes Barbados Blue; ColorLogic LEDs, ProLogic PS-8, AquaPod, AquaConnect, (3) WhisperFlo 2.5HP pumps, 1HP blower, 3/4HP cleaner pump; Pentair CC 520 cartridge filter; MasterTemp 400 propane, Rainbow 320; UltraPure UV/Ozone; Polaris 280; 7' raised spa by rock waterside; (soon) 62" fire pit, (soon) ODK; 60x40 screen enclosure
    Build - here.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by RiffeShooter View Post
    Yea, same here. I grabbed an ezpour one time and dumped it in without noticing. As my bleach is held in a 35 gallon tank and added by my Stenner pump I can only guess it got fairly diluted in the tank with the standard bleach because I had no foaming or bubbles.
    Support the site
