Thread: Stains!!
    Oct 2014
    Charlotte, NC
    1
    Stains!!
    Very new to this site. Seems very cool
    My daughter had friends over and one had a bobby pin fall out in the spa.
    I noticed rust stains about a week or so later. I put vitamin c tabs on the rust stains and it left dark blemishes.
    i used city water to fill the pool. It is salt water. Chemistry is fine.
    The stains dont brush out. Any help on ideas. Anything that can brush out these stains? Pebble Sheen finish. 3 months old.
    Pebble Sheen Aqua, 22k gallon pool w/spa, Infloor Cleaning system, Pentair 3hp variable pump with cartridge filter, 400k heater
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Stains!!
    Did you try using a trichlor tab? If no help, then try some dry acid in a sock.....
    Are you using anything that contains copper? Algaecides, maybe?
    You're done SLAMing when:
