Thread: A couple closing questions
    May 2014
    canada
    33
    Hey there. I have read all the pool closing instructions and just have a few questions.
    1. When adding the pool antifreeze do I pour it in to every pipe? Like should I detach and pour in to pipes that run between heater, pump, filter, etc? Or do I just dump it into the skimmer? Also the antifreeze diluted at all or just dumped in as is.
    2. I have solar panels on my roof. When I opened this year there was two plugs that needed to be put in. I assume these need to be removed for closing?
    3. Is the skimmer hole the only one that needs to be plugged?
    4. Do the hoes between pump, filter, heater, need to be loosened at the clamps?
    My pool is swg about 13000 gallons. In ground. Only 1 skimmer and 2 returns.
    Any other tips would be appreciated.
    Jul 2014
    Peoria, IL
    389
    Re: A couple closing questions
    1. You need to make sure you evacuate the water and or get antifreeze in every possible place. I generally remove all piping that I can (we installed unions to make this easier).
    2. Yes, you need to pull the drain plugs on the solar panels. I would assume that gravity would do the rest but a slight bit of air thru the pipes would not hurt.
    3. Not sure what other holes there are? But I plug my returns and my skimmer.
    4. I remove all my hoses and pipes and fill what is left with antifreeze.
    The heater is what always causes me worries. Don't know why. But I blow air thru and vacuum water out and pour antifreeze in etc. overkill probably but afraid to ruin an expensive piece for something so easy to prevent.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    May 2014
    canada
    33
    So you completely disconnect as many hoses as you can and store them for the winter? When I bought the house the pool was professionally closed and they had not done that. all hoses were attached, I was told they just loosened the clamps. But I like your idea better. Easy enough to reconnected in the spring.
    Just curious what you would plug your returns with. They were not plugged on opening and I'm not sure I have anything to plug them with.
    Thanks a million.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    My (most?) returns have a 1.5" threaded hole, so a 1.5" pvc plug can thread right in.
    That's how the directional eyes hole things attach, so you turn those counter clockwise to remove them, then put the plugs in their place.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    There is a sticky that addresses all the major questions on closing.
    Essential Links:
