Thread: Taylor K 1766: question re black stains in test vial
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Question Taylor K 1766: question re black stains in test vial
    The little vial I test my salt with has black stains that I would love to get rid of. I can barely make out the 10ml which I need to be able to see. Picture: http://i77.photobucket.com/albums/j4...pse0157b5d.jpg
    Normal soap like ivory doesn't cut it, and I put it in the dishwasher (top shelf) and even the dishwasher didn't put a dent in the black stains.
    Suggestions on how to remove? Maybe muriatic acid on a q-tip would work?
    Thank you in advance.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    38,290
    Re: Taylor K 1766: question re black stains in test vial
    Try some diluted muriatic acid. Odd that the salt test is making it black, I only get some white buildup where the SpeedStir pill spins.
    Oct 2013
    Chapin, SC
    1,141
    Same here, though my pill has some black at the seams which Ieaves a little black dot on the bottom center of the vial. Cleaning the white residue off the sides takes a sheet of paper towel every other test sometimes more. Since I can still see the 10ml line even with the residue in there.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    38,290
    The FAS-DPD test can turn it black. Do you use the same vial?
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    No...I keep the 2 tests separate.
    Oct 2013
    Chapin, SC
    1,141
    Me too. The vial I was saying had the black on the bottom is the same as I use for all my other tests no salt, I keep that one separate.
