Results 1 to 12 of 12
Thread: Is there a significant benefit in purchasing a variable pump?
    Aug 2014
    East Northport, NY
    155
    My info should appear below but I have a 1hp Hayward rebuilt pump and it has worked fine for 16 years. I only had to have the cord going into the unit fixed last season. My question is this:
    Local pool place is having a big sale and variable pumps are on sale. Is it worth it to pick one of these up? Should I stay with what I have until it breaks or is it truly a big difference makes on electricity bills etc?
    Thanks in advance!
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Re: Is there a significant benefit in purchasing a variable pump?
    That depends a great deal on your electrical rates. High electrical rates, more than $0.20/kwh, make variable speed pumps very attractive. I don't believe electrical rates are nearly that high in NY, so odds are a variable speed pump is not such a great deal in your area.
    38,475
    With lower electrical costs, a 2-speed (even just a motor replacement) usually make more financial sense than a full VS pump.
    Aug 2014
    East Northport, NY
    155
    Me thinks I will remain as is. They claim at this store that you can save a ton of electricity rats but if ain't broke I won't fix it.
    Thanks!
    TF-100 Test Kit
    Aquabot Bravo
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Your 'delevered' electric costs on Long Island is one of the highest in the country well over $.20 a kWh, I think more like $.25- .29 per kWh
    PSE&G LI is offering a $450 rebate on most VS pumps bought by sometime in November. A hayward superpump VS is about $650-700 on the web so your net cost would only be $250 -300
    You should save much more than that the first year.
    Also note that the installer gets $200.00 from PSE&G
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Aug 2014
    East Northport, NY
    155
    Thanks EVCharge - I can't find that program on their website. Also, the installer also gets $200? Why? Do they have to be a licensed electrician to get it?
    Thanks!
    TF-100 Test Kit
    Aquabot Bravo
    Jun 2014
    Long Island, NY
    340
    I'm on a iPhone and can post the link later or you can go to the Hayward websit and find the listing of rebates by state to get the rebate details for PSE&G LI. The installer has to be registered with PSE&G for the rebate to be vailid
    Aug 2014
    East Northport, NY
    155
    Thanks - I found it via Hayward. Interesting that the installer needs to be PE&G licensed. Not sure what they actually need to install, but plan to call them.
    TF-100 Test Kit
    Aquabot Bravo
    May 2012
    Dallas, Texas
    28
    My variable speed pump suction inlet sits lower to the ground than my old pumps inlet so the installer had to re-plumb some of the PVC. Also a variable speed pump needs a Controller-relay that is compatible with variable speeds (which needs to be wired) unless the new pump comes with it's own controller. I think it is $200 well spent. ($20 in gas, $20 for parts, $20 for vehicle, $70 for installer and $70 for the boss who ordered the parts and who trained the tech.
    16,000 gallon, IG, plaster, filter= DE 60 sq ft, Pump= Hayward EcoStar SP3400VSP variable speed, Build date= 2004, SPA, Heater= Pentair natural gas 400k BTU, Cleaner= Hayward Navigator (Pool equipment installed 2 feet above pool water level)
    Apr 2014
    California
    97
    I live in California and during the summer have step rates but normal price is .15 per kilowatt and I replaced my old pump wity a hayward e costar and run my pump 7 days a week 6 hours a day at 1000 rpm on 2 inch pipe and my pump now draws about 90watts, it saved me a good amount this summer and wity local and hayward rebate I only paid 850 for the pump so well worth the 450 extra for it.
    New Brunswick Canada
    819
    The extra cost of getting a 220 line puts some people off getting a variable speed. But, Pentair and Hayward will both be launching 110 variable speed pumps for 2015. I run my 1HP superpump on a timer, so that's basically the same as a VS running 24/7. The one downfall of VS is some heatpumps wont work on lower speeds and flash Low Flow error codes constantly.
    Apr 2014
    California
    97
    Most pool pads should be run with 220 to begin with, but if that's not the case then that would be a cost breaker at the cost of an electric an
