Thread: Should I buy a new pump?
    expo's Avatar
    Aug 2014
    Boca Raton, FL
    45
    I bought my home a few months ago. The pump seems to work ok and did not think anything about it till I went to my brother-in-laws house and you could barely hear his pump. Mine is loud. It has that "bearings are dry" sound.
    My main concern is if I would save electricity with a new pump. Here is a pic of the pump:
    Here is a not great video of the sound.
    http://videobam.com/yXvPp
    Thanks
    18,000 - IG - Vinyl lined less than a year - 1.5hp Hayward pump - Hayward AQR15 AquaRite Salt Chlorination System - Taylor K2006 Test Kit - Kreepy Krawly Great While keeping the bottom clean
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Should I buy a new pump?
    You would save a considerable amount on electricity if you switch to a 2 speed pump, on low speed it will pump 1/2 as much water as on high at 1/4 the amount of electricity. Usually high speed is only needed for vacuuming, backwashing, etc.
    expo's Avatar
    Aug 2014
    Boca Raton, FL
    45
    Quote Originally Posted by Isaac-1 View Post
    I run a kreepy krawly. does that make a difference?
    38,548
    The suction cleaner may not run very well on low speed, so you may want a timer to allow your pump to run on high speed for 1-2 hours a day and then low the rest that you need.
    You could get by with just replacing the motor on your existing pump with a 2-speed version.
