Thread: Polaris 280 Backup Valve Cycle Time
    Jun 2013
    Austin, TX
    70
    Hi, I have a Polaris 280 that's about 18 months old. I have problems with tangling of the hose sometimes and it is generally due to the backup valve pulling the unit along the side of the pool and then hanging on the hose connection/outlet. I've made several adjustments to the floats and swivels to minimize it, but it still happens occasionally.
    Just last week at was at my father's house and he has a much older Polaris 280 (several years old). His backup valve only pulls back for about 15 seconds vs mine that reverses for close to a minute. It appears that neither unit is adjustable.
    My question is whether anyone knows if the timing on the reverse valve has changed over time and if it is possible to disassemble it and adjust it manually. If I could reduce the time, it would work much better for my pool. Thanks!
    12k gal IGP/Spa, gunite, Jandy 2HP ePump VSP, Jandy CL 460 Cartridge Filter, LXI400 Heater, PebbleSheen, Polaris 280, stenner 45MPHP10 auto chorine feeder
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Polaris 280 Backup Valve Cycle Time
    All I can tell you is mine must have a sensor because right as its getting to the last bit of debris in the pool the stupid valve takes off and drags it for a good 30 seconds. Then it takes another half hour to fart around and get there again. If I didn't inherit this dumb thing with the pool I would have a robot. Same money, takes much less time, doesn't do stupid stuff.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    there is a "double acting" back up valve kit available. but first i would consider the following. make sure the hose is cut to the correct length, from the wall fitting to the furthermost point of the pool +/- 6". if the hose is to long then the "leader hose" (hose connected to cleaner) should be cut to the depth of the pool (remove the off cut from the swivel end and not the cleaner but also make sure you do not remove too much to make the total hose too short), if you still have extra hose then remove equal amounts from hose 1 and hose 2 (at the first swivel from pool wall) , check your pressure and set to 28 rpms which will equal 28psi (adjusted at the wall fitting), adjust the float behind the back up valve away approx 12 - 18" from the back up valve (the closer the float is the higher the cleaner will lift towards the pool surface, the further away the cleaner will be pulled along the pool floor.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Jun 2013
    Austin, TX
    70
    malcolmb - thanks, sorry for the delay, I have been offline for a while. I have tried all of the things you mentioned regarding the hose. I have tried multiple float placements, added extra swivels, etc. Last winter (first winter of pool operation) I had a big problem with tangling, cleaner hanging on the hose near the outlet/connector, etc. and have seemed to solve most of those problems. Now my main problem is when the backup valve comes on, as I mentioned it runs too long and it doesn't pull straight, but tends to pull the cleaner in a clockwise circle, which then ends up pulling the hose on top of itself. I will check on the "double acting" back up valve - thanks.
    Sep 2009
    Sydney, Australia
    166
    can also try rotating the backup valve so the jet stream is at 12 or 6 o'clock.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    1 min seems a bit long for a backup cycle. The unit should go into backup about every 4-5 min. if it is longer than that, the gears may be worn, or in the case of only 18 months, a defective gear box that prematurely failed.
    Factory Warranty Station for:
