Thread: Sandissimos says hello!
    Sandissimos's Avatar
    Aug 2014
    Brighton, England
    76
    Wink Sandissimos says hello!
    Hi all!
    I'm glued to this forum ever since I found it a few months ago. I live on the South Coast of England and am just having my very first pool built in our small back garden. They hope it will take between 4 to 5 weeks, but the little digger is struggling because our ground is solid chalk! I will post some pictures once I have worked out how to.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Sandissimos says hello!
    Welcome aboard finally! Glad you decided to join, and do keep us posted as they sort it out. Pictures are good....
    Essential Links:
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You're done SLAMing when:
    38,524
    Welcome to TFP!!!
    The picture storage allotment is very limited for basic members. To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    Aug 2014
    Seminole, FL
    92
    Quote Originally Posted by Sandissimos View Post
    Hi all!
    Welcome! I'm originally from Bournemouth, a few miles away, also on the south coast (you know that of course!). You're going to have a pretty short season I guess! Unless you plan to heat?
    Built 1980, 19' x 30' almost rectangular, screened 15,000 gal, plaster, Hayward DE 3620 filter (currently using cellulose), Emerson 1081 1HP pump, AquaCal Heatwave SuperQuiet SQ110R heater, Zodiac T5 Cleaner, Taylor K-2006 test kit
    Aug 2014
    Brighton, England
    76
    Quote Originally Posted by mikech View Post
    Hi Mikech, we are going to have a heater & I'm hoping we'll be swimming from about Easter until September/October. Obviously that will depend on what sort of summer we get, but we are hardy here and often swim in the sea.
    12' x 24' IG approx 9.5k gallons
    4' 8" constant depth, vinyl liner, air to water heat pump, floating solar cover, 1 skimmer, 2 inlets, 1 underwater LED light, sand filtration system & now, finally, a TF100 test kit
