Thread: Replacing Pentair Amerilites with Pentair Intellibrites and interfacing with Aqualink
    I have 2 Pentair Amerilites and 1 spa light. Pool lights have been leaking for years and I am ready to change out. I have a Jandy Aqualink RS control system with a One Touch keypad in my house. My question is whether I can locate the Intellibrite controller in a waterproof out box near the J-box for the lights and have the dial set on the light show I want. Then just let the Aqualinks timer turn the lights on and off as usual. My concern is that it appears the Intellibrite controller has this big green on off button and I don't want to walk out to my pool equipment to turn on and off each time. I also don't want to run new power from my house to the pool equipment for the controller. Can the controller be located at the pool equip and controlled by the Aqualink?
    Thanks for any help.
    35,000gal /IG/Pebbletec/Sand/Pentair 2 HP single/2006/Taylor K-2005/Spa Slide & Waterfall/SWG/Polaris/Intellibrite 5g Color
    38,251
    Re: Replacing Pentair Amerilites with Pentair Intellibrites and interfacing with Aqua
    Sorry for the delayed response, but automation is an area where not many members have experience.
    Maybe someone will see the bump and be able to help.
    No Problem, I called Pentair and they tried it there and it worked. I have installed it that way and all is well for those considering the same setup.
    Mar 2011
    441
    Quote Originally Posted by srockrae View Post
    This is highly dependent on which firmware you have.
    20X40 30,000 gallon gunite pool
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by racket View Post
    It sure is, like my situation, I have jandy lights that work great with the aqualink pda and pentair laminars that work but don't work as well as they should.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Mar 2011
    441
    Quote Originally Posted by robl45 View Post
    There are 2 different types of Pentair Laminars out there. The older ones had their own logic for the lighting sequence and the thumpers. The new ones are the exact same sequence as the intellibrite lights.
