Hi just bought a house with an above ground pool which needs a few holes repaired and a new liner amongst other things. It's a tricky situation since one end of the pool was covered by my deck and he needs to pull up some of the boards to replace the liner. I got a quote of $1675 for the following. Materials $725, Labor $950. Am I getting gouged?
New Beaded 20 Gauge Full Print Liner
Patching the Wall
Foam Padding
New Skimmer and Return with Gaskets
Pulling Up Boards
Re-Groom Bottom of Pool
New Bead Receiver (track for liner)
Clean out and add Sand to Filter
Start Pump to Check if it Works
New Pool Cover with Air Pillows Tension Cable
Winterize Pool
One Year Guarantee On Work
Patching the Wall
Foam Padding
Pulling Up Boards
Winterize Pool
