Thread: Re - plumbing pool questions
    Apr 2014
    California
    97
    I have an older pool with only one suction line above the ground going to the pump and only 3 return jets, there was a float/diverted mechanism sitting on top of skimmer basket which I assumed allows the pump to pull from floor drain equally with skimmer since there is only one line but my pump will not prime with the diverted in the skimmer basket but when skimmer is by itself jt primes in less then 1 minute, pump is e costar variable. My main question since pool deck cement has seen better days is should I re plumb and fix the main drain?
    With out water being pulled from bottom drain I've struggled with a few black algea spots at deep end of a 10 ft deep pool
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Re - plumbing pool questions
    Can you point one of your returns so it blows down there? That may help with the circulation.
    Apr 2014
    California
    97
    The returns are at the other end with no nozzles about 32 ft away
