Thread: Hot tub wire cut / gecko topside controller
    Oct 2014
    Overland Park, KS
    3
    Lots of pics below
    bought our house a few months ago and the hot tub was there so I don't have much info on it. If anyone knows a brand or etc it would be appreciated.
    Randomly a few weeks ago we noticed the hot tub was running as if everything was on (pumps, lights, etc). I flipped the breaker and left it off for two days, turned it back on and everything was still running wide open.
    I crawled under the deck and it looks like the wire going from the Gecko K-8 topside control is sliced in two spots. Bought some mouse bait to hopefully stop this in the future.
    Should I just replace the whole top side controller or can you do just the wire? I have a repairman coming out next week but would rather do it myself if possible. Or could it be something else?
    ImageUploadedByTapatalk1412873678.148590.jpgImageUploadedByTapatalk1412873690.909638.jpgImageUploadedByTapatalk1412873700.297603.jpgImageUploadedByTapatalk1412873709.389309.jpgImageUploadedByTapatalk1412873719.913704.jpg
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Hot tub wire cut / gecko topside controller
    Can't tell from your photos; is there exposed copper? If not the wire is probably fine...just wrap some e-tape around it.
    Oct 2014
    Overland Park, KS
    3
    Yes. From what I can tell at least two wires are cut through. I assume it's an animal because it wasn't me...
    Oct 2014
    Overland Park, KS
    3
    Just wanted to be sure everything would kick on if those wires are cut...
