Thread: Do I remove multiport/spider gasket or set to "winter"
    Jun 2012
    Blaine, MN
    106
    When going over the winterizing steps I see that it states to remove the multiport/spider gasket (not sure how I missed that in past years). This is the third year I have closed the pool. I have never removedthe port before, just set the filter to "winter".
    What is best?????
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    May 2013
    Long Island NY
    419
    Re: Do I remove multiport/spider gasket or set to "winter"
    Quote Originally Posted by blondemarcello View Post
    What is best?????
    I have never removed it either. I just turn it to land between 2 stations so the water can trickle out and not freeze in the valve.
    Also on the side of mine there is a drain nut.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Jun 2012
    Blaine, MN
    106
    Thanks. Yep, got the drain nut. Although the first year I did it wrong and got a whole bunch of sand coming out. oops.
    blondemarcello
    Minnesota
    May 2013
    Long Island NY
    419
    You must of blew thought the skimmer and inturn it went through the sand filter then the valve.
    Jun 2012
    Blaine, MN
    106
    Nope, starting to need the peepers to see and didn't see there was two parts to the drain plug. I went for the biggest "nut", unscrewed it and got sand.
    blondemarcello
    Minnesota
