Thread: Intermatic timer for actuator
    Oct 2014
    San Marcos, Ca
    62
    I have a standard dial Intermatic timer. Since I replaced the pump with an Interflo VS, the timer doesn't control anything but there is still power to it.
    I would like to control an actuator with the timer. Is the voltage output from the timer correct for an actuator?
    Re: Intermatic timer for actuator
    Not directly. You will need an appropriate transformer. Also, you need a SPDT timer, or a slaved relay, to be able to switch the actuator back and forth between two positions.
