Thread: Polyquat (and Chlorine) Questions
    Jun 2010
    Toronto, ON. Canada
    230
    Hello,
    Am planning on closing our pool this Sunday ourselves for the first time (with the help of someone who does this regularly).
    Questions:
    1. Where do I buy polyquat from in Toronto?
    2. How much do I need?
    3. When do I put it in? Prior to draining below the returns or after? I would assume after so as not to "waste" any (and run the pump with the skimmer closed).
    Same for Chlorine... If I want to boost the FC, when should I add? After draining?
    Thanks!
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Polyquat (and Chlorine) Questions
    The additions need to be made while you can still run the pump for a good while to mix the chemicals with the water.
    Polyquat comes in 30% and 60%, so how much you need depends on which you find. The 60% dosage runs about a pint per 10000 gallons or ~38000L
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by JohnT View Post
    Awesome! Thanks!
    I can run my pump even after dropping the water level as I can close off my skimmer and use just my main drain.
    Now to find where I can buy polyquat here in Toronto.
    New Brunswick Canada
    819
    Any pool store in TO should have Polyquat. Check around to see who carries Mursatt Chemicals, they sell a 40% and 60%
