Thread: Air blower for spa
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    Air blower for spa
    Is there a way to tone down the force of the air from an air blower for a spa? The PB put in a 2 HP blower and the force of the air is almost beating you up when its on, as the wife says. Is a lower H/P blower needed or can you tune the existing one down? The spa is fine without the blower on, just don't get the massage feel that the air brings(with much force).
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    38,295
    Re: Air blower for spa
    I think you can just add a ball valve in the pipe below the blower and partially close it off. The blower should be able to bypass any extra air without damage.
    Although I would like for someone else to confirm this.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Have you tried the spa with the blower removed not just off? Some spas will work just fine without a blower. Also, how far is the spa from the blower?
    Also, closing off the air flow tends to make the blower much louder so another trick is to put a tee after the blower with a valve on the bypass of the tee so that you can adjust how much air is bypassed.
    Mark
    38,295
    Ah ... that is a better idea on how to "bypass"/divert the air flow.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I don't have a blower, but I do have a Jandy valve on the pipe, that I shut it off to heat faster. if I added a blower I could quite easily regulate how much air gets to the spa with the valve.
    chiefwej
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Also drilling some holes in the pipe below the blower helps as well.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
