Thread: SWG / BBB System: Set-up Order?
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Dear All,
    I've just installed a salt water chlorine generator to my hot tub.
    I'm also going to try the BBB system as well.
    Can anyone tell me in what order I should address the various chemicals added to a freshly filled tub?
    Should I add the CYA first, then add bleach to get a correct Chlorine level (which will then be stabilised), then look at pH, then TA, then borate levels and finally add the correct salt amount?
    (How long a wait between adding / adjusting for each chemical?)
    Or is there better order in which to address these variables?
    D
    Jacuzzi J480 (2008) 1700 litres, Balboa ozonator, Delta EZ-18-120 UV lamp via custom 6-way 2-tier timer solenoid array, 2 x Waterway 4HP main pumps,
    1 x Aqua-Flow 1/15 HP circ pump, ChlorMaker IL SWG, SmartSeal + Roxul skirting insulation, 8' x 8' ThermoFloat Spa blanket, 100" x 100" Gator coverall
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: SWG / BBB System: Set-up Order?
    The order you gave is fine if turning on the SWG is the last step. You can add the chlorine while the CYA is still dissolving (i.e. I wouldn't wait a day to add the chlorine). In a spa with good circulation, you don't need to wait very long between additions. With jets, just a few minutes between additions is fine; with no jets but with circulation then 5-10 minutes should be plenty. Spas circulate very quickly and well.
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Hi ChemGeek,
    Thanks for your verification of my intended methods.
    I am sure the more I consult this forum, the wiser I shall become.
    - D
