Results 1 to 18 of 18
Thread: Going underground in MA
    Sep 2014
    Chelmsford, MA
    28
    Red face Going underground in MA
    The Committee (MIL, FIL, Wife and myself) decided to retire our 32 year old Gibraltar pool (AG) so my MIL can have an easier time getting in and out. We did a bunch of research, got lots of quotes and decided on an L shape pool with rounded corners (Vinyl) .
    The pool is measured in the schematic as 37' long, 16' wide with the L going 12' long and 24' wide. The deep end is 8' deep and the shallow end is 40" deep. I'm told this is mostly standard stuff. What I have yet to figure out is how many gallons of water this thing is going to take to fill it.
    They came out last week and started digging. The metal shell went in and we are now waiting on the town to come inspect, they were supposed to be out last Thursday.....
    I have some progress pictures (you can see the dismantled pool in the background...waiting for disposal at the local scrap yard):
    We are considering the in-ground solar cover reel, but I'd like to hear from anyone with experience over here: http://www.troublefreepool.com/threa...-system-review
    Thanks for reading,
    Rich
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: Going underground in MA
    I figured about 24500 gallons. Others may have better educated guess. I did it via Pool Math.
    http://www.troublefreepool.com/calc.html
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Sep 2014
    Chelmsford, MA
    28
    Thanks! That is somewhere in line with what the PB told me late last night, his number was 21,400.
    Up next is figuring out what our kit is going to look like. I am unsure if the PB's plan is to finish and close the pool for the season, or if they plan on opening it and running it to test it out for a bit....But come next season I want to have on hand most of what I'll be needing, how much of this do you all keep on hand and how much do you just know where to get it when you need it?
    Salt (cheap and easy to store, no reason not to have it)
    Bleach (this one I'm not sure of, since we have the SWG I don't think I'd need much at all of this right?)
    muriatic acid (when opening a pool do people typically need to lower, or raise PH? Which of this or Borax do you keep on hand?)
    Borax
    Baking Soda
    cyanuric acid in stabilizer or conditioner form (This would be buy on demand, the pool store is closer than any other...)
    Should I order my test kit now, or wait until next year.... I guess that might depend on if we are just closing it or leaving it open for any length of time...
    Thanks all! I'll be back with more pictures later today.
    Rich
    21,600 Gallon IG vinyl L shaped Pool
    Hayward DE3620 Pro-Grid DE Filter, Hayward 1HP super pump, AutoPilot SWG, 350,000BTU Hayward Heater
    TF-100 Test kit with options (salt strips, Borates, mixer)
    9/30/14 Dig Began....
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Order the TF-100 asap. Its a great value and has alot of what you need and plenty of it. Bleach. I go through a bottle and a half a day but I have no SWG. Others with SWG's will chime in on that I am sure. On the other stuff, honestly I would buy it as you need it. I bought the baking soda, muriatic acid, borax and all that is huge boxes 2 years ago and haven't had to use any of it. A water test on your tap water should give you an idea of what you might need though. Once you have your test kit, test the tap water and post your results. The experts here will be able to guide you better with those readings.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,490
    Welcome! Yeah on what Glock said!
    -Buy test kit
    -Buy CYA and add
    -Do NOT buy a lot of bleach yet. It will lose it's strength over time.
    Keep showing us your pics!
    Kim
    Sep 2014
    Chelmsford, MA
    28
    I ordered my test kit, it will probably be here before the water gets put in. I have been reading the Pool School, and about Borates and I think I want to add them to the pool. The extra expense of 60$ for the borax and about 28$ in MA seems reasonable for the buffering ability it adds, but it does leave me with an ordering question....
    1. Pool Water gets delivered
    2. PB has bags of salt out there, I assume he is going to get the water up to 3000ppm salt, and balance the PH at least.
    Do you think I should put the Borax in there now, THEN close the pool so it is there when we open it in the spring, or should I just wait until after opening it to muck with all of that?
    Trying out the new Flickr account, just for this thread
    Here is the equipment set up on the pad, the electrician was off to the side making up the panel....
    Untitled by rich.schelin, on Flickr
    Here is the interior of the AutoPilot SWG/pump controller:
    Sep 2014
    Chelmsford, MA
    28
    Electrical inspections are done, liner went in this morning and the water is being pumped in now!
    image by rich.schelin, on Flickr
    A different perspective, 9,000 gallons to fill in the deep end and a couple of inches across:
    No test kit yet, so no numbers coming soon, the kids want to jump in
    Jul 2012
    Tallahassee, FL
    30,490
    That is a pretty liner!
    I say let the kids jump in! You just have to find a way to keep the sand out!
    Kim
    Sep 2014
    Chelmsford, MA
    28
    The electricians finished hooking everything up, although the lights are out of sync color wise, they do look nicer than pictures can show. The backfill is slated for Tuesday....
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    Looking good
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    Sep 2014
    Chelmsford, MA
    28
    The dirt piles were pushed back in, the kids froze (twice!) and we have a nice mud-zone in most of that portion of our backyard
    Here is a panoramic shot of the proposed decking (blue lines) and the proposed fence (white line)
    Pool School is scheduled for Monday, along with the Fence guy to come out to take a look and the Decking guy is coming out to re-evaluate due to changes to the plan along the way....
    The pool is green and the filter isn't running yet, but at least the PH is 7.3....
    Apr 2014
    Stony Brook, NY
    159
    Love the cuddle cove! I have the same swg, works great. BTW, does anyone think the de filter is on the small side??? I have a 16k gallon pool, and my filter is bigger. Just curious, don't want you to have problems in the future.
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
    Sep 2014
    Chelmsford, MA
    28
    My concerns at the moment are pump size and filter size, I want to look into them this morning. The pump is a 1Hp Hayward "super" pump. What concerns me the most about it is that after the builder re-stated half a dozen times that the pad has to be level with the pool edge, it is easily 2-3 feet up above the pool edge, let alone the water's edge...
    I'll post back when I research and see what the Pb says...
    Rich
    Sep 2014
    Chelmsford, MA
    28
    The general consensus is that we want to turn over the water in 8 hours. The pool is just under 22,000 gallons, so we need a flow of 45.83 gpm.
    The one site said to measure from each skimmer, and the main drain to get the head distance:
    Skimmer1 = 40', Skimmer2 = 41', Main Drain = 63', Average = 48'
    The table for the 1Hp Super pump (SP2607X10) says at 50' of head the pump does 50 gpm, which is just above our ~46gpm required.
    The DE3620 is rated to 72GPM, I saw someplace the "ideal" rate was around 50GPM.
    So it seems like this should work fine, even if the 2-3' increase in height slows the GPM slightly.
    Rich
    Sep 2014
    Chelmsford, MA
    28
    The decking guys were here earlier this week to deliver our jump rock, and prepare for the pour, they apparently ran out of rebar and will finish that when they come back for the pour. Right now we are waiting for the electrician to come and tie the ground wires to the rebar, and then the inspection will be next Tuesday, and the pour will be Wednesday. The pool company came out and closed the pool, here's hoping these noreasters knock it off
    Sep 2014
    Chelmsford, MA
    28
    The weather held, I'm told they are almost done, the pictures are from before I headed into work this morning. Now we wait a week to acid wash to let the stones shine through, and then another week to put the winter cover on it.
    My little guy loved how the cement truck rolled in, the aggregate is being mixed in the foreground:
    A couple shots before I had to head to work.
    Biggbotti's Avatar
    Nov 2014
    Ny
    112
    Looking good!
    Sep 2014
    Chelmsford, MA
    28
    Cement has been in for a few days, waiting a week for the acid wash. To the left is the fire pit, I had some cracked stones so I need to get replacements, there will be a circle stone area around with planting beds in a circle around it. The expansion joints have red tape over them, under it is a tan that matches the cement pretty well.
    Still lots of landscaping to do, assuming the snow holds off!
    IMG_2223 by rich.schelin, on Flickr
