Thread: Winterizing a heater???
    So we had a heater installed a couple of months ago. Last year, I closed the pool myself. It wasn't too bad. But now I have the added complexity of the heater. I know I need to drain it by removing a drain plug. And I should blow it out (how? not sure).
    What do you need to do to make sure the heater is ready for next spring?
    24 ft. above ground pool, 13,500 gallons, installed summer 2013
    Cartridge Filter, Hayward 1.5 HP Power-Flo LX pump
    Main drain
    5 happy swimming children
    NW Indiana
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Winterizing a heater???
    Drain it out but also try to isolate only the heater as much as you can with valving and blow it out with air just like the rest of your equipment.
    Isolated Spa - 345 Gallons
