Results 1 to 7 of 7
Thread: Valve actuator plumbing for solar - something looks wrong
    Oct 2014
    San Marcos, Ca
    62
    I just bought a house with a 13k pool and a rooftop solar system. I have been trying to dial in the solar and have been going through the plumbing configuration. Something seems off.
    I had an Intellifo VS installed to replace the single speed pump that was there. There is a Goldline solar controller which will be replaced by the SolarTouch in the next few weeks.
    In this pic, the solar controller is off. When the solar is on, the curved side of the handle is to the right.
    When the solar turns on, the actuator turns and diverts the water to the solar - I assume this turns 3 off and opens 1 and 2.
    But when the solar is off, 2 must be off and 1 and 3 open, right? If so, what is stopping the water from flowing to the solar panels?
    Is this the right set up?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Valve actuator plumbing for solar - something looks wrong
    Normally the solar valve is between the filter and solar supply not the return so it is backwards but it still should work ok. Is there a check valve between the solar supply and the filter?
    The only problem with the setup is that the panels will still fill when the solar valve is off. In very hot climates this can be an issue because the water will get very hot and could possibly soften the PVC.
    Mark
    Oct 2014
    San Marcos, Ca
    62
    There is a check valve.
    I am in San Diego so it does get out. Should I change it?
    mas985's Avatar
    Pleasanton, CA
    11,737
    If it hasn't caused a problem to date, I would worry too much about it. But looking at the layout, it doesn't look like it would be too hard to change either and you could salvage the valve so it is up to you.
    Mark
    Oct 2014
    San Marcos, Ca
    62
    Replumbed it. Water to solar comes straight from the actuator and water coming back goes to the pool. I put a check valve in the solar return so water doesn't go backwards. I also put an inline thermometer in the solar return so I can maximize heat gain. Much better!
    38,295
    What do you mean by "maximize heat gain"? Ideally the solar panels should only raise the temperature a couple degrees to be most efficient.
    Oct 2014
    San Marcos, Ca
    62
    I mean dial in the pump rpms to get them as low as I can.
