Results 1 to 8 of 8
Thread: Montucky hello from Montana! New pool at hotel is driving me nuts.
    Montucky's Avatar
    Oct 2014
    Big Mountain Montana
    7
    Hi there! I have been working in a hotel for over 5 years now and take the maintenance of our pool and spa very seriously. I take care of it as if my own children would be swimming in it. I do not have a CPO but my friend at work who has moved to another department has one and I stole his book and pick his brain from time to time.
    I was shown the basics and expanded upon it over the years. Not an expert by any means but I take pool chemistry seriously and look forward to taking the online CPO class and finishing it up with the actual class they hold in Montana once a year. Not having my friend in my department to streamline the process of our new indoor pool and hot tub has been very frustrating. I have found several problems with the new install and have had some of my concerns corrected but the new system is so complex that I keep finding very odd things with the build.
    Aside from the basics as a helper to the pools when I started out, I learned a bunch from the Taylor test kit book that comes in the blue plastic box, I researched online and I read the CPO training book on subjects that relate to what I am experiencing with my system.
    I take care of a 50,000 gallon outdoor pool that we will be closing soon, a 5,000 gallon outdoor spa, a new 14,000 gallon indoor pool with a waterfall and an 2,000 gallon spa that is also indoors.
    The new seresco dehumidifier is not plumbed in to the pool filter so we are wasting a bunch of money and water not pulling it back into the pool. The waterfall evaporates a lot of 80 degree water and also increases the PH. The surface is also playing with me. It is a grouted stone and will probably raise the PH for a few months.
    The one thing that is really DRIVING ME BATTY right now is the automation. Our builder put in two Pentair Intellichem controllers and I just got done reading the manual. I will ask about the problem I am having and if it was done wrong or why it was done this way.
    I appreciate all your help and wisdom. My mouth and way of communicating is a bit foul in the real world. I will try to not get political, foul or offensive on this forum. If I offend you or get out of line, please let me know. I go off on tangents at times and need to be corrected.
    Thanks and have a good one!
    Nic
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Montucky hello from Montana! New pool at hotel is driving me nuts.
    Welcome to the forum. While we deal with residential pools here, there is a lot of helpful information.
    Keep it sane & clean, and we won't have to worry about you. Otherwise........
    Essential Links:
    38,301
    Welcome to TFP!!!
    I highly suggest you check out this post from Chem Geek: http://www.troublefreepool.com/threa...-is-not-taught
    And of course read through Pool School. There are some very important chemistry aspects that are ignored in the CPO training you have read.
    Which test kit do you have? Hopefully one with the FAS-DPD chlorine test.
    Mar 2007
    San Rafael, CA USA
    12,082
    You can keep the pH from rising as quickly, especially in the pool with the waterfall, by lowering the Total Alkalinity (TA) level and setting a higher pH target. According to Montana state regulations for water chemistry parameters you are allowed to have your TA as low as 60 ppm and your pH as high as 7.8 and can compensate for the Calcite Saturation Index (CSI) by increasing Calcium Hardness (CH) if needed. This chart shows how over-carbonated a pool is with respect to equilibrium with air at various TA and pH levels. You can also use CO2 instead of most of your acid and bicarbonate (you'll still need some acid, but no bicarbonate). I gave a short TED-style talk (only given 7 minutes which is way too short) on this topic at the Worldwide Aquatic Health Conference (WAHC) in Portland. I've uploaded the presentation you can get in this link.
    Montucky's Avatar
    Oct 2014
    7
    The state of Montana requires us to have the big blue box. Taylor Test Kit K2006c.
    I like the kit and would not consider a color matching chl test. We test 4 times a day so we eat up the dpd powder! There is a floating rumor that the powder is the most nuclear stuff on the property.
    Still looking for the old blue crusher.
    I would like to post photos but it seems that they have very little storage on this server.
    38,301
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    Montucky's Avatar
    Oct 2014
    7
    You're freaking awesome! Thanks! I appreciate you sharing your knowledge with me! I just take orders really well. I was told to keep the alkalinity at 100 so the boiler does not **** out on us. This was the order given after a new pentair boiler failed months after install. the guts were corroded. Granted, the exterior ground was never connected and no check valve before the line hit the inline chlorinator.
    38,301
    The corrosion is more likely due to a low pH condition which could certainly result from exclusive use of trichlor tablets. The TA is related to how easy the pH can swing, it is a buffer. The trichlor would have been lowering the pH and the TA, but really the low pH was the problem not the TA.
    If you are going to continue to use the trichlor tablets, you are going to have to keep an eye on the pH and TA dropping and raise them back up. But, we generally do not recommend the exclusise use of tablets due to the CYA rise they cause.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
