Results 1 to 7 of 7
Thread: Has anyone ever forgotten to remove their pool thermometer when winterizing?
    Jun 2014
    Freeport IL
    46
    First year pool owner, in Illinois where it gets very cold. We were so methodical about winterizing the pool, but unfortunately we forgot the pool thermometer was never removed from the pool, dah! We have the winter cover on, wrapped it in that saran wrap type plastic to protect from the wind and then realize the thermometer is still in the pool. It was a cheap thermometer hanging on a rope. Although I looked at it daily, I don't know if it is plastic or glass, guessing plastic, purchased for about $8 to $12 at local pool store. We believe at least part of it is in the water. A friend thinks the worst that will happen is it will crack but not burst glass (if it is glass) fragments into water. I have no idea what is in the thermometer to register the temp.
    Can anyone weigh in on this, do we need to remove the thermometer? Thanks
    18"X48" Intex Ultra Pool; AG; 6424 gal; instal 5-26-14
    First time pool owner; NW IL
    Krystal Clear Model 635 Filter Pump-Cartridge A; 1500 gal/hr
    Krystal Clear Saltwater System Model CS8110 added
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Has anyone ever forgotten to remove their pool thermometer when winterizing?
    No big deal I say. Most thermometers with red liquid are alcohol or other organic solvent based. So the liquid itself is no problem. If it does burst, there will be very little glass, if any that falls in pool, if it is even glass.
    Sent from mobile device. Beware of brevity and spelling errors!
    Isolated Spa - 345 Gallons
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If your concerned about it, why not just take it out ?
    I just remove mine. 😎
    Jeff
    May 2012
    Montville NJ
    545
    Quote Originally Posted by pwrstrk View Post
    I just remove mine. ��
    I assume this his is IN the pool in its entirety, and he used teh shrink wrap on the pool cover - he does not want to undo that.
    I doubt he will have any problems with it. He may need a new thermometer, but that is about it.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Most of the thermometers I found by Google go down to 10 degrees F which tells me they shouldn't freeze as that is 22 degrees below freezing. Add that to the fact that its out of the wind and in water, I think you will be fine. How cold does it get there?
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Jul 2014
    Peoria, IL
    389
    It got down to the negative single digits (-5?) by us last winter and we are not far from the op. I would just leave it and pick up a new one in the spring.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    It happened to me on year and the thermometer was ok, but part of the clear plastic cover broke. I'm still using it as the thermometer itself still works. I just had to vacuum up the clear plastic bits which was small potatoes compared to the number of worms, worms are really yucky!
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
