Results 1 to 7 of 7
Thread: Algae outside the pool
    Aug 2008
    North of Tampa FL
    14
    We have a birdcage and there is algae (I assume) on it. My husband power washes it occasionally and of course the runoff gets into the pool. Should we raise the chlorine in the pool before he cleans the cage to prevent it growing in the pool? I don't think there is any way to add bleach to the power washer but if there was would that do it?
    We also have algae in some of the cracks in the pool deck and at the base of the birdcage. I guess this might explain our algae problem.
    14188 Marcite pool. 1/2 hp pump Hayward cartridge filter. SWCG Goldline T-15 Turbo cell. Spillover spa. Birdcage.
    Re: Algae outside the pool
    I would bump up your FC BEFORE you wash the cage.
    Perhaps you could put some bleach water in a pressure sprayer and apply it to the algae spots on the cage and patio before you powerwash it. Then you would only be getting dead algae into the pool.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Do not run bleach water through your pressure washer as it may ruin the insides of the machine. I would suggest using a spray bottle with bleach water before you clean the cage.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Aug 2008
    North of Tampa FL
    14
    Thanks. I think we will do both. Spray the spots and up the FC. Looks like A TS is coming so we aren't going to do anything right now
    Guest
    Some pressure washers can run bleach, some cannot. It depends on whether the intake is before or after the pump. If it's before the pump it can ruin the washer. My craftsman has the intake after the pump and I can run pool chlorine through it.
    Usually the instruction manual will tell you what cleaning compounds are safe to use in your pressure washer.
    Aug 2008
    North of Tampa FL
    14
    waterbear
    Do you mean you can run pool chlorine through or you have? What kind of situation would need running pool chlorine thru the pressure washer?
    I have a terra cotta tile roof that's in need of cleaning. I've seen cleaners clean other roofs and it smells like bleach but now I wonder if they use chlorine.
    Quote Originally Posted by Jenn_in_FL
    waterbear
    Jenn, bleach IS chlorine!! 8) The 'pool chlorine' or 'liquid shock' is a higher concentration (10 or 12%) whereas regular bleach is 6%.
    My suggestion was using a pump-up pressure sprayer, like you would use for bug spray or gardening.
    My powerwasher is a dinky electric thing, but I can attach a container with bleach or cleaner right near the trigger, so it does not go thru the machine at all.
