Results 1 to 8 of 8
Thread: SLAM-ing now---- can't get a good read??? Added over 100 drops!!!
    Oct 2014
    Jacksonville, FL
    67
    I just tried to re-test my FC and CC with Taylor Kit K-2006...
    Tested at 12pm and FC was 6.2 and CC was .2.
    Just tried testing at 3:45pm and it isnt working... I have added over 100 drops of R-0871 and it is still pink!!!!
    HELP!
    Don't even know my CYA bc the pool was too murky to get a good reading.
    Frustrated.
    How often should I be testing when SLAM-ing?
    Attachment 33396
    ________________________
    22,000 gallon pool---In ground--Oval--16x32---Vinyl liner -----Cartridge Pentair filter
    Pump= Century HSQ 165 (installed 2016) ---New liner in 2014 when we bought, orig. build date unknown
    Test kit Taylor K-2006---Manual vacuum---Bottom drain not in use, odd plumbing setup
    Re: SLAM-ing now---- can't get a good read??? Added over 100 drops!!!
    Welcome to TFP!
    The test is only reliable up to about 100 drops. Because you are measuring by steps of 0.2, that means an upper limit on the test of 20, which isn't really all that high. You should use a 10 ml sample, so you are measuring by steps of 0.5, which allows the test to measure FC levels up to 50. There really isn't any use for the 0.2 steps, the added precision isn't really useful and it uses up reagents much more quickly.
    30,414
    Usually not. What does the CYA view tube tell you if you simply put in pool water? (do not add R-0013). It will very likely be 0 CYA
    How much chlorine did y9ou add between 12:00 and 2:45PM?
    Oct 2014
    Jacksonville, FL
    67
    JasonLion--THANK YOU! Followed your advice and it took 58 drops.
    FC is now 29-pool math told me I want to shock at 28. It said 38 for mustard algae shock, but I am nervous to ruin my liner?
    Which should I do?
    Added 7.5 gallons at 10.5% around 12pm.
    PS- When my husband ran to the store to get more chlorine he had them test the water just to see what it would say and they said FC was 5.0!!! This was 1 hour before we tested with the FAS-DPD and got FC 29.
    Trying not to be mad about all the pool store advice we've gotten these last 6 mos!
    Smykowski's Avatar
    Sep 2011
    3,065
    Use the "regular" SLAM number. Damage to the liner occurs with high FC and no CYA, or from prolonged exposure to low pH water. If you use the TFP values, you'll be fine.
    30,414
    I am confused. Have you determined your CYA and I am not seeing it posted?
    Sep 2013
    Connecticut
    728
    The poster (in another thread) measured CYA of 70, using K-2006. She was still getting used to doing the CYA test, and not 100% confident of the result, I think.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    30,414
    I see it now, SP, Thanks. It is a good reminder how confusing it gets when OP's run multiple posts.....I was lost.
