Thread: General test questions
    Jun 2013
    Philadelphia, PA
    143
    Working on getting things optimal for the Winter closing (We're still swimming since the weather has been nice and the heater is working well.) Generally, our chemistry is always good anyway, but I've struggled with getting pH up this year. Still am.
    I did adopt borates in our pool last year, and I think I have too much in. So raising pH by that method is probably out. I used test strips for the borate, but I'm horrible in reading these things. See attached for a pic of the test strip 15 seconds after a 5 second dip. To me it looks like 50-80. Borate.jpg
    I've just been aerating to try and get pH up. Both return jets are spun up and breaking up the surface pretty well. Went from 7.1 last week to 7.2 this week. Pump runs about 7 hours a day.
    Also trying to get my CYA up. I added 24 ounces by volume of CYA last Saturday. Waited until this Saturday to test. Went from 50 to 55. Makes no sense. Dropped it SLOWLY in the skimmer with the pump running.
    Full battery of tests below. Suggestions?
    FC 6.5
    CC <0.5
    pH 7.2
    TA 90
    CH 210
    CYA 55
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    30,432
    Re: General test questions
    You can still raise the pH quite easily by using 20 Mule Team Borax. Use PoolMath for the dosage and pH should respond accordingly.
    Most all pools rise naturally in pH when an SWG is in use....I have no idea why yours is not.
    At this point, I would be unconcerned about CYA. I would readjust in the Spring.
    Jun 2013
    Philadelphia, PA
    143
    Dave - my only concern is I THINK I'm already beyond where I should be on borates. I know it's not necessarily harmful, but we already seem to smell them, since adding them last Summer. . .
    TFT 100
    30,432
    Well, 7.2 is an acceptable pH so I would just leave it. I can't imagine your SWG not pushing it higher sooner or later......you're blessed if it doesn't.
    Jun 2013
    Philadelphia, PA
    143
    Thanks, Dave. Yes - hasn't pushed it up all Summer. Odd indeed. Mixed blessing I guess!
    TFT 100
