Thread: Pentair Valve Actuator Repaired
    tomzo's Avatar
    May 2011
    Escondido, CA
    77
    Greetings,
    I thought I would report on a successful repair of two valve actuators that stopped working on me. Rather than spend a few hundred bucks replacing them I poked around inside and found that the limit switches that start and stop the valves were faulty. A quick search on ebay led to replacement parts for $16 per valve. After a 5 minute repair job the valves work like new.
    Look for item number 221537493021 on ebay.
    Tom
    21K Gal Vinyl In Ground with block wall sides (Self Built with help), Pentair Easy Touch controller, Pentair Intelliflo pump, Intellichlor salt system, Clean and Clear Plus filter, SR Smith Typhoon Slide
    Re: Pentair Valve Actuator Repaired
