Thread: Pump Replacement Part
    I have a small leak in my pump and it looks like it's from a drain screw(?) that is broken.
    Would a local pool store or hardware store have a replacement or is this something I need to order online? The o-ring looks good.
    Thanks!
    Lynn
    12000 Gallon Freeform Pool
    SWG
    Jandy AquaPure 1400
    Leslie's DPD Complete Chlorine Kit + FAS/DPD Chlorine Tester and Swirler from TFP.com
    Tree covered lot - cottonwoods and crepe myrtles. Great shade during the summer, miserable fall cleaning leaves from the pool.
    30,419
    Re: Pump Replacement Part
    What's broken about the screw? You might try some teflon tape (about three wraps) if the screw is not broken.
    Oct 2013
    Chapin, SC
    1,141
    It's plastic and the first thread below the O ring is cracked.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Yes, it's cracked and water is leaking from the pump.
    I went to my local Warehouse Pool supply but they didn't have one.
    SWG
    Jandy AquaPure 1400
