Thread: Instaling spider gasket- need sealant?
    People,
    Got a new spider gasket for a hayward "valve(?), and Im not sure if I should cement down with silicone (other?), or just lay flat, then apply a thin coat of lube on top. Advice appreciated!
    16,000 gal in ground, marcite. FL.
    Aug 2014
    Jensen Beach, FL
    6
    Re: Instaling spider gasket- need sealant?
    I just did mine and used some silicone to hold it in place, then lubed the top. The pool store told me to use marine goop to hold it in place. Put it back together and let it sit for 24hrs before using. Wrong or right this is what was recommended to me and it seems fine so far.
    Andy
    early 90s, 13K gal, IG Plaster, 1HP marathon, DE Nautilus NS-36, Spill over Spa w/1.5HP rebuilt A.O. Smith, Gulfstream Heat Pump (RIP, considering new options), solar sun rings.
    thanks, parm.
    Oct 2013
    Chapin, SC
    1,141
    Goop is glue! Use silicon lube.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
