Results 1 to 10 of 10
Thread: Pump usually running 24/7 due to surface debris -- determining how much to cut back
    Sep 2014
    Hamilton, Canada
    70
    Hello!
    New pool owner here. (see first thread -- has photo of how foilage heavy our pool is, with branches overhanging ~1/4 the surface area of our pool)
    We usually keep the pump running 24/7 to keep debris and water quality manageable, even when we go to bed for the night with the pool cover on (for algae management) and when pool cover is off (for foilage debris management too). Except when I heated up the pool but turned off the heater and want to preserve the heat overnight, I turn off the pump to prevent the cold ground from cooling down the water as it's pumped (I feel cold water coming out of the jets, half an hour after I turn off the pool heater -- indicating the ground is cooling down the water).
    I have an issue of foilage and lots of debris in the pool, so running the pump allows a lot of debris to reach the skimmer eventually. But may want to cut back a bit next year, as I've reliably kept the pool clear and will also be getting better test kits too.
    Do other people with foilage-heavy swimming pools, have recommendations on how to cut back the pumping? Perhaps turn off during the expensive electricity rates (TOU) -- but keep it running at all other times and during the weekend when people are using the pool? I'm wondering how surface debris builds up if you don't run the pump 24/7.
    Became homeowners/poolowners in 2014 -- Now Resident Experts In Cheaply Hot-Tubbing (95F) A Large 20,000 Gallon Pool.
    20,000 gallon concrete/vinyl, 32'x16' size, Raypak Digital 266 Heater, Hayward Tristar VS pump
    38,285
    Re: Pump usually running 24/7 due to surface debris -- determining how much to cut ba
    Every pool is different. Why not try cutting back on the pump and see how it goes?
    Have you read this: Determine Pump Run Time
    One option would be to run in short blocks spread throughout the day so that the debris is skimmer every so often before it can sink. Could start with trying 3 hours on, 3 hours off, etc ... although that still may be more than you need.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Even for a lot of foliage, you shouldn't need that much run time unless you are trying to keep the pool spotless all the time. It is ok to leave debris on the surface or on the bottom of the pool but I realize that some people are more picky than others.
    Also, are the skimmers effectively removing the debris? They should clear the surface in an hour or two at most. If not, then you may need to make some adjustments with the returns or perhaps valve settings.
    Mark
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    i was thinking maybe one hour on then two hours off
    in cycles through the day
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Sep 2014
    Hamilton, Canada
    70
    Quote Originally Posted by mas985 View Post
    if we let water level go half an inch to an inch low of the "recommended line" marked on the skimmer cover, the skimmer is effective on half the surface debris, especially the flowers that fall (we have a rare Rose Sharron tree too) and hemlock needles. Most of the pine needles tend to overshoot the skimmer though, most of the time.
    There is only one skimmer. I considered: Is a 2nd skimmer a worthwhile long term upgrade for a foilage-heavy pool?
    Oct 2014
    Niverville Manitoba
    2
    We use a mesh cover on our pool. Its on all the time except when we're using the pool. We have a number of large trees around our pool as well. We're in Canada so I ordered our cover from poolsupliescanada.ca
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by mdrejhon View Post
    That could be because something is wrong with the weir door. Your skimmer has a weir door correct? That is what makes it possible to run at a variety of water level heights. Without it, the skimmer would only work better at lower water levels.
    Actually, adding a second skimmer can be counter productive because the flow rate is then split between the skimmers so they are each less effective. If most of your debris is around the skimmer, you are better off with one skimmer.
    Mark
    Sep 2014
    Hamilton, Canada
    70
    There is no weir door, just an opening about 6 inch tall, with a line marker in the middle. Never heard of weir doors till today, thanks for the new search term to google...
    Sounds like I should look at researching how to get a weir door installed. The plastic skimmer cover (Equator brand) with 6" tall rectangle hole is removable, being inserted into a rectangular cutout in the vinyl, allowing a same size opening with a proper door to be attached, I hope. No peg holes suggesting a missing door, but need to look closer. I imagine it is a standardized size?
    Sep 2014
    Hamilton, Canada
    70
    Quote Originally Posted by Briankf View Post
    We have a solar cover because it works well with our pool heater (we heated the pool to hot tub temperatures last weekend, 96F) so that catches debris too, and a pole brush that allows us to sweep the debris to the end of the pool cover.
    But often, the sweep time versus skim time is a wash, time-wise. So if we swim everyday during midsummer hot days, the solar cover stays off all week and all night, skimming by saving time. Keeping cover open seems to keep algae down by keeping the pool cold during the hot summer days when we like it colder. Unless we aren't swimming for a week or heating the pool during current cooler times, then keeping the solar cover on and sweeping the solar cover saves time.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Skimmers don't work too well without a weir. You will need to find the model# of your skimmer and see if they make a weir for it. They are not standard sizes.
    http://www.inyopools.com/search_weir.aspx
    Mark
