Thread: Aftermarket above ground pumps/filters?
    Aug 2014
    So cal
    17
    Has anyone used a pond pump/sand filter for your above ground? my nephew has a intex and the included filter is a plastic piece of junk( had a algae bloom that required many many filter cleanings(cartridge is about the size of a 20oz soda bottle lol)
    Thanks for any ideas.
    ps Besides the higher costs, is the reason that those above ground pools do not come with a bigger pump a safety thing?
    38,274
    Re: Aftermarket above ground pumps/filters?
    I think it is to just try to be as cheap as possible. The larger Intex sand filters and 2600+ pumps are not bad and many members upgrade to them.
    Jul 2014
    Bastrop, Louisiana
    199
    Im not sure if a pond pump is going to give you the flow needed to circulate the water efficient enough. Although i dont think its impossible, a quick search turned up THIS SETUP which is a direct replacement without any rigging or adapting hoses to install.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    Aug 2014
    So cal
    17
    Thanks, that looks a little more durable, and reasonably priced!
    Quote Originally Posted by one_knight4u View Post
