Thread: Adding Diatomaceous Earth to Intex sand filter questions
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    I am just getting to the end of a SLAM and want to add DE to my sand filter to help the filtration. 1st attempt was yesterday and I added the 1/2cup recommended and seemed to be working and I had to go to work. Came home and filter had a low flow indication and high pressure on the filter. I back washed this morning and tried again with around 1/3 cup. About 2hrs later I had to back wash again because of high pressure and didn't add any more for now. My question, is this normal and filtering that much better than regular sand or am I using too much? My water is almost back to normal from SLAMing, just a little murky right now but not bad. Should I expect to have to backwash and put more DE in multiple times a day for a while?
    How much DE is everyone else using on the Intex sand filters? Do you put it in dry or mix with water? I did it both ways and it seemed to work better wet. When I put it in dry it seemed like it passed through the sand filter.
    Thanks in advance.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Adding Diatomaceous Earth to Intex sand filter questions
    Watch the pressure gauge as you add it in small amounts. Stop adding when pressure rises 1psi. Then backwash when pressure rises 20 - 25%.
    Support the site
    Sep 2013
    El Cajon CA
    126
    Quote Originally Posted by tim5055 View Post
    That's what I did but don't know if I did it slow enough or too much or it just got clogged up that fast.
    38,524
    What does your water look like? Sounds like the filter and DE are doing their job by catching something.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    I concur with jblizzle. You wanted fine filtering and you got it. But all those bleached algae carcasses have to go somewhere.
    Sep 2013
    El Cajon CA
    126
    Water is fairly clear, just finishing up the SLAM process so there is probably still some fine stuff in the water.
    I will keep at it, maybe start with smaller amount of DE and when the water gets cleaner add a little more. As is now I run around 5psi clean and 20% would be 1psi so if I raise it 1psi there isn't much left before I need to back-flush.
