Thread: anybody use an aftermarket RF remote?
    Murfreesboro, TN
    i'm looking for a way to control volume without needing a line of sight remote. i think they make RF remotes that work thru wall that retrofit. ideas? ... l-extender
    Cal C.
    22k ig vl, hayward 2sp northstar, hayward pro series sand filter, aqua logic ps-8 wireless controls with swg, hayward (eus) heat pump, polaris 280 cleaner.
    I haven't tried this yet but want to!! You install a special rechargable battery into your existing remote and it is supposed to turn it into a wireless RF remote. That way you keep all of the functionality of the original remote.
    You can see it here:
    Richardson, TX
    These are what I use: ... B000069EV0 (changed the link there are some reviews on Amazon, good and bad)
    Bought at Frys, about $ was the cheapest one I've seen. I use to for my stereo equipment that's in a cabinet so I don't have to open the door anymore; their about two feet apart and work great at that range, maybe 2feet apart.
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    Memphis, TN
    I am using the remote control extender that Brittmer is talking about. I use it for my pool area and have the receiver and cd player safely mounted in a garage storage room out of the weather and where there is easy access to electric.
    It is as simply as it use a replacement recharagable battery in your remote (limited to remotes that use AA and AAA batteries). I haven't tried to test the limits on the range, but I'd have used it sucessfully and regulary at a distance of 75'. My signal has to penetrate a brick wall to get to the receiver.
    Below is the company that I purchased the unit from (as well as other items from time to it has my recommendation), and this item is slightly cheaper than Smarthome. ... sp?id=1055
    Good luck,
    33000 IG Vinyl, Sand Filter, Circupool SWG, Polaris 180 w/Booster Pump, Mosquito Misting System, Home Automation
