Thread: gone for the year
    Sep 2013
    Connecticut
    728
    gone for the year
    With one of these ring top pools, 'closing' the pool looks pretty final. As of last weekend, the water has been dumped in the woods, and our pool has been cleaned, dried, folded up into a large unwieldy bundle, and put into an old plastic car-top carrier that we conveniently found out by the side of the road during the summer (one of those things shaped like a giant Burger King box). We'll put the carrier into a shed, or least up off the ground with a tarp over it -- hopefully that will keep the pool safe from water and critters until warm weather returns. All that's left now is a damp tarp on the ground in the backyard, with falling leaves already accumulating on it -- kind of a sad sight, and definitely marking the end of summer here.
    Cleaning and putting away a pool like this is somewhat laborious and time-consuming, but, surprisingly, not really much worse for the 5500 gallon pool we had this year than it was last year for the smaller 1000 gallon size (in case anyone is thinking of going for a larger seasonal pool, but worried about additional work setting up and taking down).
    Now I just have to put the test chemicals away into a cool dark spot (basement) for the winter, and bring in that last half-finished bottle of 12.5% pool 'shock' -- I guess I'll just dilute it to half strength, and move it to the laundry room. Kind of the opposite direction from bringing the laundry room bleach out to the pool, as is so often recommended on the forum.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: gone for the year
    All good things come to an end. Hope you had a good summer with the pool. See you next year!
    ​pssst - you can stick around and help others over the winter too!
    Isolated Spa - 345 Gallons
    Sep 2013
    Connecticut
    728
    Yes, it was a good summer. Not entirely 'trouble free', but at least we knew what we were doing when algae showed up. Kids loved the larger pool, and they were agitating occasionally for something even bigger -- I guess that's the typical slippery slope around here .
    I really meant that the pool is 'gone for the year'; pool owner might stick around here yet for a while... although I've found that my interest in pool issues usually wanes by the time we're shoveling snow.
