Thread: De filter housing leaking
    Jul 2014
    Carlsbad California
    14
    Hey all, drained washed pool and filter. Cleaned the seal and the housing applied lube tapped and tightened
    The clamp. Housing is leaking. New oring 6 months ago. Cleaned the filter before with no leaks. Any advice appreciated.
    Thanks
    8000 gallon Inground pool, pebble tech , swc aquapure 1400, pentair 4000 DE filter 4060.
    38,271
    Re: De filter housing leaking
    I would just pull the top and make sure there is not a piece of debris on the o-ring. Mine is over 5 years old and I have never seen any leaking around the seam.
    Jul 2014
    Carlsbad California
    14
    Mine has never leaked before either. I may try to put the old oring back In and see what that does. I really cleaned the oring channel thinking that would help but no.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Rule of thumb: the last thing you worked on is the first thing that breaks. Open it up again and doublecheck things. I smeared a little lube around the inside of the clamp so it slides easier as it cinches down. I don't know if it helped any, but I thought I'd toss that out.
