Thread: Pentair Intellibrite light Controller
    Oct 2014
    Manitoba
    1
    I have 3 Intellibrite 120 volt lights with my controller that isn't working properly. I have the 3 lights daisy chained together directly to the Controller. I am thinking that from reading this that you need to create a junction box between the lights and the controller. Is this correct?
    Mar 2011
    441
    Re: Pentair Intellibrite light Controller
    Quote Originally Posted by Peterpuck View Post
    The power goes into the line side of the intellibrite control and out the load side. So if all 3 lights are hooked to the load side it will work fine.
    20X40 30,000 gallon gunite pool
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Are all three pool lights or are the three a combination of spa and pool? I believe the controller has a limit of 2 pool lights with enough room to add on 1 spa light. Or if you had 1 pool light and a couple spa lights.
