Thread: New owner seeking suggestions for electronic test kit
    Sep 2014
    Gilbert, AZ
    32
    Hello, everyone!
    I've just closed on a house with a pool and no doubt will have a lot of questions once I move in. Initially, though, I'd like some input on an electronic testing kit versus the traditional kits. I would prefer being shown an exact figure instead of trying to gauge various shades of colors.
    I would think that would be beneficial as well when inputting data into one of the pool calculators or apps (I'd also welcome recommendations for a good smartphone app for keeping track of testing data).
    LaMotte seems to provide a wide range of options, but not sure which one would be best.
    Any comments/suggestions welcome.
    38,480
    Re: New owner seeking suggestions for electronic test kit
    Welcome to TFP!!!
    There are VERY few members here who would recommend a digital tester ... most of us do not trust them. They are expensive, require a lot of calibration, and then you still do not know if it is giving you valid readings.
    The Recommended Test Kits do not require any color matching (except for the pH test). If you can count drops, you can get accurate test results. There is just no need to have the artificial and questionable precision when you have no idea how accurate it is.
    There are many threads discussing phone apps, depending on your OS.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Welcome to TFP!!!
    Best Android app I've used is PoolPal.
    Isolated Spa - 345 Gallons
    Sep 2014
    Gilbert, AZ
    32
    OK, I've gone ahead and ordered the TF-100 kit.
    Is there anything I can/should do before it arrives?
    A little background on the pool:
    It is an older (1996) in-ground plaster pool that is around 10K gallons (don't have exact measurements yet). It seems in decent shape but is showing signs of age (could probably use a replastering). Once I get more details, I'll add them to my signature.
    The house was a foreclosure and the previous owner had let it go green last year. The city came in and cleaned it up and it was left empty for a few months over last Winter. It was refilled during the Spring and looks like they simply put chlorine tabs in a float to maintain it. (Possibly a pool service was used, but I don't know). The water is clean and clear and looks great to the naked eye.
    Should I just wait till the test kit comes before doing anything? Or should I get rid of the floating chlorine tabs and start adding bleach manually in anticipation?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Quote Originally Posted by Sansfear View Post
    Great choice, You saved me from finding all my comments about the LaMotte
    Give it time, don;t rush into anything.
    Yes! The tabs are raising CYA and at this point you don't know if you can afford it.
    Support the site
