Thread: Bromine behaviour
    nofa93's Avatar
    Sep 2013
    Montreal, Canada
    46
    Bromine behaviour
    Is it normal that when I add a larger than usual amount of bleach(8.25%) (10oz+) in my 440 gallon bromine tub, the water shows a heavy green tint for roughly 30-45 minutes? Is this just a sign of high bromine levels due to the reaction with the bleach? And if so, shouldn't it show longer?
    Thanks
    20,000 Gallons Vinyl 16x32 Inground with Stamped concrete decking. Hayward Sand Filter. DIY Diaphragm pump injection system. K-2006C Test Kit.
    450 Gallons Standalone Acrylic CALSPA 2006.
    Canadians, Get your test kit here!.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Bromine behaviour
    High bromine levels especially at lower pH will tint the water yellow (extremely high levels would be more toward orange). Green doesn't sound like bromine unless your spa surface is blue in which case yellow+blue = green. It may not last in color if bromine has something to react with in the spa.
