Thread: Help picking Energy Efficient Pump
    Mar 2014
    South Carolina
    7
    Split by moderator from HERE. Please ask questions in your own thread and not in another member's old thread. Thanks, jblizzle
    I have read this entire thread and it is A LOT of great information, however; I am confused on what to do. I have an inground pool, 17,000 gallons with 3 returns, Pentair Sand filter, I use a vacuum cleaner all of the time. The motor in my pump has gone out. It is a Jandy SHPM, 1.5 HP, single speed.
    After reading all of this, should I replace just the motor or switch to a dual speed to save monthly electricity costs? I need to make the most economically sound decision. I need to save as much $$ as I can. Suggestions?
    17,211 gallon, in-ground, fiberglass, sand filter (Pentair water), Jandy Stealth Pump model SHPM 1.5 HP, pool installed 2007, 2 wheel suction-side pool cleaner.
    38,475
    Re: Help picking Energy Efficient Pump
    With a suction cleaner, you will not be able to get the full benefit of running on lower speeds as it may not be enough flow to move the cleaner. You could certainly add a timer to run at high speed for a few hours each day for the cleaner and then switch down to low speed for the electrical savings.
    If there is nothing wrong with your pump, then just replacing the motor with a new 2-speed motor with a new shaft seal is likely the cheapest option.
    Mar 2014
    South Carolina
    7
    Thanks for the info. Can you tell me how long I should/can run the motor on low for my pool size and get optimal filtering? I was told by a pool company that I can run my current single speed pump for 12 hours and leave it off for 12 hours a day. I was also told that if I switch to a dual speed I shouldn't run it on the low speed long because the water will not circulate enough. Can you clarify that for me?
    38,475
    Well, that pool company was full of bad information, tragically that is all too common.
    Read this and follow up with questions: Determine Pump Run Time
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I run my pump on low speed for 6 hours a day and water has always been great. Only time I use high is to mix bleach addition, vac and if I need more skimming. 😎
    Jeff
    Mar 2014
    South Carolina
    7
    Thank you! That was VERY Helpful!
