Thread: pool pump recommendation
    Jul 2013
    McAlester Oklahoma
    17
    Can anyone put in their 2 cents about a pool pump for 12x24 above ground Intex. I have a 1/2 hp 1600 gph but doesnt circulate enough.
    AG intex pool 12x24x52" apprx 8500 gal. Intex sand filter, Hayward pump 1 HP, 60GPM with added SWG system, Water Tech Pool Blaster Max Vac. (Iron in faucet water)
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: pool pump recommendation
    If that is the stock pump that came with the intex it is probably not really 1/2 hp. A standard above ground pool pump 1/2 hp to 1 hp should be more than enough to circulate the water in your pool. If you are getting a weak return flow try backwashing the filter and see if the flow improves.
    Love TFP? Become a
    TFP Supporter!
    Jul 2013
    McAlester Oklahoma
    17
    Thanks Zea3, Actually came home from a short outing and the thing wont even come on now! It's been really loud lately and probably on its last "leg".
