Thread: Solar angle
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Solar angle
    Lots of great solar panel info here. Getting ready to go with two Solar Bear panels. Had a question. Is it worth making the frame adjustable? My best March/September angle is 30 degrees, best April/Aug angle is 22 degrees. I don't really care about any shallower angle in mid summer, water will be plenty hot. It would be fairly easy to make an adjustable rack, but only adjusting what comes out to +6" at top and -6" at bottom seems like maybe not worth it. I think 30 degrees for ends of season probably makes more sense.
    Also with Solar Bear going horizontally, I was planning on tilting East end up 6" so it would drain without having to blow it out. Just gets a little uglier since I'm putting them over my Pump pad rather than on roof.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    New Brunswick Canada
    819
    Re: Solar angle
    Adjustable is the cats meow if you can do it, 90 degrees is optimum. As the sun gets higher in the sky, then you could flatten them out to get that degree.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Solar angle
    Great info here: http://www.fsec.ucf.edu/en/consumer/...ools/index.htm
    I don't think it will make much difference being in the south.
