Thread: Ok, if cost were not a factor who makes the best solid safety cover?
    I'm in the market for a cover. It seems that the prices are all within $200.
    I live in a coastal mid-Atlantic region. Typical lows are in the 20-30's, extreme minimum 10-15 degrees F.
    My pool is a basic Grecian 18'x36' center 4'x8' step off pool.
    I have a lot of trees that make leaving the pool open a hefty chore, so that's not an option.
    My choices are down to "Covertech" Safe-N-Secure lightweight solid, GLI Supreme Solid, or Loop-Loc Ultra Loc II solid.
    It seems to me that the Loop-Loc is more durable, which is my main concern. Am I correct in this assumption?
    Thanks.
    covertechind.com/?product=safe-n-secure-safety-cover
    http://www.glipoolproducts.com/product.asp?ProdID=6
    http://www.looploc.com/pool-safety-c...ltra-loc-2.cfm
    24k gallon inground vinyl liner pool, 8'-3' depth, 2 skimmers, 3 returns, basic 5 chem kit.
    Hayward: DE-60 filter, Superpump VS, AquaRite salt chlorinator w/T-Cell 15, TigerShark QC robot. Jacuzzi hot tub ~350gal. Air blower type, w/8 jets.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Ok, if cost were not a factor who makes the best solid safety cover?
    I say Loop Loc, but I admit that is without much formal research. I've just seen what my friends have and like.
    Support the site
    May 2013
    Fort Lauderdale, FL
    423
    I'm going on the second year with my loop-loc solid with mesh drains. Awesome cover. It even held up to our massive porch/deck contruction project last spring with contractors stepping on it, boards and nails landing on it, and my mother-in-law even fell onto it without any problems.
    When you get a foot of snow, the cover sags down to the water level, so no issues there. Loop-loc says no more than 15" below the coping for the water level.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Thanks for the replies. I went with the LoopLoc solid with mesh drain panels.
    $200 higher than the rest, but usually higher quality costs a bit more.
    Hope I'll be happy with the purchase.
    There is very little online for a consumer to compare.
    LoopLoc seems to offer the greatest detail on the construction and materials of their product. So, if the others don't provide this info, I can only assume they are using cheaper materials and construction practices.
    May 2013
    Fort Lauderdale, FL
    423
    I use a wayne automatic pump on a step to keep water levels in check. Highly recommend.
    Rockland County, NY
    52
    Just make sure to keep an eye on the water level if you are going to experience periods of heavy snow. Built up snow and ice on your cover will cause it to sag putting a lot of pressure on it. I try to make sure the water level is just below the coping so that the cover will not sag as much. Some folks use heating mats on top of and aerators below the cover to keep ice builds and dams to a minimum.
    22,000 gallon ig vinyl solar heated (panels and cover) zeolite filtrate
