Thread: Rust around the bottom
    Jun 2010
    Mississipppi
    17
    Pool is 5 years old with a deck around it. The signature here has a link to what it all looks like...my question is do I need to be concerned about the rust I found around the skimmer. See pics attached.
    17,000 gallon Sand Dollar II 24 Round AGP with deep end 4'-7'
    1 HP pump
    Sand Filter
    Check it all out here http://www.seizethepage.com/backyard-oasis/
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Re: Rust around the bottom
    Does that area stay wet? You might consider digging a trench around it and laying down some perforated flex drain.
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    Jun 2010
    Mississipppi
    17
    Its wet a lot, lots or rain and splash out.
    1 HP pump
    Sand Filter
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    It would concern me. If it is just surface rust, you can prob scrape it down to bare metal then paint it. If you have soft spots in the wall, that would be even more concerning. At the very least, I would try to get the grade to slope away from your pool and try to get the base to dry out.
